Old 01-04-2016, 08:39 PM   #23 (permalink)
freebeard
You'll have to help me with what you mean by 'cut-out.
What sendler said. I checked for a third page before I hit Submit for this:
Instead of the traverse cut it has a notch, which I presume is for the driver's sight-line. But the mirror is under the influence of a larger body, which might mitigate the sub-optimal form.
I thought there were wind tunnels that could add snow. Maybe they have heated leading edges.
The lower corners of that elliptical form are the hard part. Morelli resorted to pumped air from hubcaps, since he didn't have a flat-four air pump in the lower rear.
aerohead (01-05-2016)
