Old 01-05-2016, 04:20 AM   #12 (permalink)
bobdbilder
bobdbilder's Avatar
Knight - '03 Proton Waja
90 day: 37.15 mpg (US)
Whoopee - '01 Proton Wira 1.3 Aeroback
90 day: 38.69 mpg (US)
Originally Posted by Piwoslaw View Post
My P307 has A/C (the condenser is right in front of the radiator) and only 1 fan. The fan kicks in when the coolant temperature reaches 98C. If A/C is active, then the fan keeps coolant temperature below 82C, which is a bummer if you are trying to keep the engine running hot for FE
You might be mistaken. What regulates the engine temperature is the thermostat. This closes during engine startup. Typically the coolant temp sensor situates close to it. It opens mechanically when a preset temperature is reached. The radiator and fan reduces coolant temperature.
Bear in mind that this singular fan setup also need ventilation of the engine bay. In a different discussion, this was researched by Dr. Karmann and was used to modify airflow around the windshield. A small engine compact car may achieve this by simply removing the weather strip or seal where the windshield meets the hood. Leaving a small strip where fresh air inlet is so that engine heat might not enter the cabin.
Bigger engines with different layouts may require bigger sized outlets. I seem to recall side air vents were in fashion at one time. This time it could actually be useful.
