Old 01-05-2016, 08:08 AM   #5 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by mcrews View Post
....so h0w do you know it WASNT the rear gear change that improved the mileage....
Fair question.
Top gear on the dead 42RLE had a ratio of 0.69. Top gear on the replacement NSG370 has a ratio of 0.84. This represents about a 21.7% increase in propshaft rotation speed, for a given vehicle speed. If I were to have left the original 3.636 rear end in place, that should have resulted in a definite increase in fuel consumption.
The FDR was 3.636, while it is now 2.87. This represents about a 21.1% decrease in required pinion input speed, for a given vehicle speed.
These two changes almost cancel each other out, and the net decrease in engine speed (about 3.9%) does not account for the 10.1% decrease in fuel consumption.
Put it another way - Engine speed at 60 MPH was about 1850. Now, it's about 1780. There is no way that this change in engine speed (~3.9%), by itself, would have resulted in the measured decrease in fuel consumption.
.and why not include that info in the first post......
Because I forgot? I only regarded the rear end swap as a necessary adjustment to counter the larger top gear ratio of the installed NSG370, nothing more. I figured that the 3.9% drop in engine speed that I calculated back in April of last year, would have given me a very modest 2% decrease in fuel consumption. This is based on the rule of thumb that a percent change in fuel consumption will be about half the percent change in the rear end ratio. The 2% change would have been rather hard to measure as it is just above noise.
You do bring up an interesting idea - What if I had left the original 3.636 rear end in place? Engine speed would have been about 2250 RPM at 60 MPH, which would have resulted in a net increase in engine speed of... 21.7% from when the 4-speed was still installed. I would have expected a 10.9% increase in fuel consumption just from swapping in the NSG370, if I were to have treated the engine speed increase as a result of swapping in a (nonexistent) 4.43 rear end.
The Following 3 Users Say Thank You to t vago For This Useful Post:
mcrews (01-06-2016), UltArc (04-18-2016), Xist (02-04-2016)
