Old 01-06-2016, 01:28 AM   #14 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Even if you wouldn't get regenerative brakes, a vacuum booster still seems kinda overkill for such a small car. And an electric vacuum pump would be sucking some precious kWh...
While I agree that kWh are precious, I'm not concerned about a vacuum pump wasting them. Unless you're running a big vacuum pump constantly (which there is no need to do either), you'd be measuring in "mere" watt-hours. The pumps I've been eying use maybe 1 amp at 12 volts, and it would be lucky to run for 5 minutes total per typical trip, at a guess.
What doesn't seem so easy to find is an affordable vacuum switch, which would make this particular task a lost simpler.
