Old 01-06-2016, 09:19 AM   #305 (permalink)
Daox
I thought about the 1500W heater too. I decided against it when I learned that a 15A 110V outlet is only really rated for 1380W continuous draw (80% of the breaker rating). At some point would like to run a couple other things off the 110V plug in, so I need some overhead too though.
I also felt the coolant hose coming out of the heater this morning, and it was HOT. I'll have to get my IR temp gun and get a reading off of it just for giggles. If I was going to a higher wattage heater, I'd definitely try to mount the heater in a better position for better natural convection. Its too far off to the side right now IMO, but it was easy to install there.
The other option that I'm pursuing is an electric water pump which would circulate the coolant while the heater is plugged in. I need my garage back to finish up that project though.
