Originally Posted by jamesqf
May be a dumb question, but have you checked to make sure the intensity isn't just turned all the way down?
I was thinking exactly the same thing but thought it might be taken wrong and backfire.
Roll the switch from limit to limit, might clear up the windings in the rheostat. Check fuse, jump the switch for full on. Bad connection at the panel to wiring harness interface. Dry solder joint on printed circuit board. Follow the juice starting at the fuse box.
regards
mech
