Old 01-11-2008, 07:15 PM   #3 (permalink)
jesse.rizzo
Hyundai Accent - '01 Hyundai Accent
90 day: 38.4 mpg (US)
Gixer - '97 Suzuki GSXR600
90 day: 43.12 mpg (US)
this doesn't sound quite right, for example:
Through two revolutions of its crankshaft, the ME firing cycle is equivalent to a 32 cylinder reciprocating engine, that is, it fires 32 times
but later he says it is a four stroke cycle engine. So the spark plug is firing 31 times into an already combusted mixture?
Also,
Pistons travel only the same direction. No reciprocation, only stop and go.
What does this even mean?
The ME has no valve --just open ports with no restriction. Air flow action is one way.
How can you compress the mixture if there are just open ports?
This whole thing just leaves a lot unanswered.
