Originally Posted by t vago
The Jeep Wrangler used this transmission on the 3.8L V6 engine (which was what made this swap possible - the 3.5L and the 3.8L V6 bellhousing bolt patterns are nearly identical). The Chrysler Crossfire also used this transmission, but with a radically different bellhousing bolt pattern.
The first gen intrepid came stock with a 3.3, same as 3.8
