Old 01-06-2016, 07:16 PM   #13 (permalink)
aerohead
pad/rotor contact
Originally Posted by DragBean View Post
Does anyone know how much drag hydraulic disk brakes create?
The break pad doesn't come completely off the disk when you aren't pressing the brakes so you get a little drag.
Worse off on my car the brake rotor is radially pretty uneven (not unbalanced) but I hesitate to get them turned and put new brake pads on them because I don't have any braking issues and the pads still have enough meat in them to probably last for the remaining life in the car.
But I might be able to justify the work if it improves mpg.
The disk brake advantage over drum-type IS that the pads are always contacting the rotor, enough to wipe away water during inclement weather driving,and allowing 'stopping',where drum brakes might cause a rear end collision.
I bought a 1964 Karmann Ghia pretty cheap after a 16-year-old rear-ended a Cadillac during his first rainy day drive.
For safety reasons alone,I welcome the miniscule brake drag.
