Old 01-06-2016, 07:15 PM   #8 (permalink)
zroadster
Toothless - '03 Ford Focus SVT
Team Ford
buzz box - '14 Kawasaki Ninja 300 SE
Originally Posted by austingsx View Post
Well there ya go, it seems it actually be more accurate than a car with manifold regulated fuel pressure. My assumption was based on a road trip I made through the mountains; my 'guino readings were very off. Usually I'm in coastal plains or small hills. The continuous climbs with low MAP used considerably more fuel than a more even terrain.
Well of course. I live in the mountains. Typically going up hill drastically reduces MPG. My Focus may be stock but it will still only manage 10-14 mpg going up hilly terrain, even at economical speeds. They weren't off, that's really what it takes to go up a mountain.
Most modern cars don't regulate fuel by pressure but by pulse width. Fuel pressure MUST remain constant, with only injector pulse width being changed. Some vehicles do regulate fuel pressure by speeding up or slowing down the pump, my focus is one of them, but it does it because it is a returnless type fuel system. It maintains a constant 40psi and wont run right if it is more than 3 psi more or less than that.
There ARE systems that regulate pressure to adjust fuel input. Bosch made them for Porsche in the 70s and 80s called the CIS. Constant Injection System and anyone who has owned one of these cars can tell you they are a royal pain in the tush to try to keep in optimum tune. I can tell you from first hand experience, if you don't have the OIL CAP tightened with a good gasket in it the AFRs will be off, it will stumble, and cold starts will suffer.
