Old 01-07-2016, 12:38 AM   #14 (permalink)
DragBean
PizzaRimBoy
True. That's why you should tap your brakes when you're in the rain every so often. Most cars have drums in the back anyways. Probably the bigger thing is that spreaders would require pushing on the brakes a little harder which would reduce the time your brakes engage by a very small time. If your brakes are calibrated right this probably wouldn't even be an issue.
