A quick one eighth left/right turn on the steering wheel pushes the pads away enough so that there is little or no drag.
Most modern cars have disc brakes front AND back. Having said that, there are some that do have drum brakes on the back; these are usually low priced autos that are relatively light in weight (for a car).
If the caliper doesn't float freely, then one of the disc brake pads on that wheel will drag and partially brake constantly. I had a Crown Vic that did that.
How does one calibrate brakes?
