Maybe if the 3 shielded connectors for the current sensors had gold coating on the crimp pins? I think I just have normal tin crimp pins on those. When you cycled the 24v power after plugging in the current sensor all the way, it said a new message that there was a current sensor fault, so then you cycled the 24v power again, and it then went away?
