Old 01-08-2016, 01:14 PM   #2514 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
Maybe if the 3 shielded connectors for the current sensors had gold coating on the crimp pins? I think I just have normal tin crimp pins on those. When you cycled the 24v power after plugging in the current sensor all the way, it said a new message that there was a current sensor fault, so then you cycled the 24v power again, and it then went away?
That is what I remember. I think that's what the video shows, except that I touched each of the connectors again between the 'new message' and when the controller powered up without faults.
If gold plating helps ... what does it cost?
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (01-08-2016)
