Hi thingstodo, i dont know exact your problem but my experience tells me that the corrosion is formed when two dissimilar metals touch, so the solution for me was to always use connectors that are the same metal, and if they are different you must solder it.
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
