The male and female connectors are 100% compatible? I mean, are well matched? Because otherwise able differences of connectors, brands, versions, etc. can not make enough contact.
If you have crimp type connectors, you are right in not solder it, IPC international standards explain that connectors are for crimp and dont must solder because the reasons you mention.
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
