Old 01-10-2016, 11:09 AM   #19 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I've used a few and never had one fail, but it's worth spending the extra few bucks on good solar.
The savings will really come from the lead acid battery lasting longer.
A one amp solar panel on a 40ah flooded battery should never be at risk of over charging it, if it was a plug in trickle changer then you'd want 100/1 ratio, it works because the amps going into the battery dip as it gets full and lead acid can handle it.
