Just for the halibut, How about just taking one of the cars that you like (70's or 80's) and adding a later model tranny with Overdrive and a lock-up converter. (Available in a Packard in 1955 or in a GM car in the mid 1980's.) Then convert the car to throttle body fuel injection (Holly) and you've brought an oldster into modern times.
Taking another tack, the GM small block has remained roughly the same size since 1955. And Ford's small block has remained roughly the same size since the mid 60's.
What particular vehicle do you plan on altering?
