I made a rear belly pan. It covers up everything all the way up to the rear lower control arms, then tucks up nicely so the wind wont catch on it. Hours of work went into this.
I first jacked up and took off the rear wheels, then did my best to trace a outline then cut the two black boards to size doing one board at a time. Trimming through out the process is a given, so dont cut off too much in one go! I used screws and bolts along the edges and in a few places I had to use big zip ties.
See how it tucks up nicely.
Had to drill through the trunk.
