Welcome! The Fit's a fun little car.
You've already got the SG, so your next move should be to block the lower grille- and watch those coolant temps! I got mine in February of 14 and didn't block the grille until spring 15. It didn't just help with aero, it helped with warmup and heat retention. I don't have to wear my hat and gloves all the way to work like I did pre-block.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
