Old 01-13-2016, 08:06 PM   #407 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ettore_M View Post
Hey guys. I just discovered MPGuino and I want to install one on my '99 Lancia Ypsilon.
I built it and programmed the chip with the latest code (193tav), but I got this problem. The program (or chip or even LCD) seem to be slow. Really slow. When I push the right button to change page, I have to long-press the button and the page changes after like 5 seconds. It's slow.
Does anyone have this problem? I use a ATMega328P and 20MHz crystal.
Thanks
Hector
Interesting. Can you go to the system time page? Can you see if the time itself updates normally? If so, then the timing itself should be correct, but there might be something wrong with the wiring hookup to your buttons.
