Originally Posted by Fat Charlie
The upper grille is tiny, the lower one is a gaping wound that ducts air through the radiator and compresses it underneath the car. Block that one.
![](http://ecomodder.com/forum/attachment.php?attachmentid=17356&d=1429113889)
It's coroplast spray painted black, and the lower pic is with the block. ![Big Grin](/forum/images/smilies/biggrin.gif)
Damn, Charlie, you made it so slick I didn't even notice it there.
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
I just thought the second pic was with different angle/lighting and more shade over the radiator.
So how did you insert it? Did you have to remove the top plastic cover by the hood latch?
Also does anyone with a Honda Fit 2nd gen know why the underside of the hood has that plastic duct for directing air from the upper grille to the battery, brake fluid and clutch fluid containers? I think the engine fuse-box is around that location too.
