Old 01-14-2016, 03:11 PM   #2528 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by P-hack View Post
I think the clap method is more than anyone could ask for as long as the time index is accurate, should be good enough to piece it together.
I hope that is enough data to figure out if something goes wrong
FYI, speaking of video testing, just picked up a $200 seek xr (android), it is a little picky about android models (needs OTG with power, 4.3+), works on the kids onetouch out of the box but not my xperia z1s without adding power.
went with it over the flir because it has a much wider temperature range.
Is that an infra-red scan of your cat?
Seek XR ... Hmm .. Does it give you an actual temperature chart for the colors or are the colors a certain number of degrees apart? Maybe a comparision of relative heat?
