Old 01-16-2016, 05:27 PM   #413 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by Ettore_M View Post
Yeah. Here it is.. It's your 193 code but with a few minor changes (Startup page name and inverted brightness setting for PNP driver).
I compiled it with avr-gcc for DF_CPU=20000000UL and programmed it with avrdude.
Hector
Well, I programmed it into my MPGuino using the latest version of the Arduino IDE, and it works normally. It's actually kind of neat to click on the middle button, and watch brightness actually go down and then cycle back to full bright.
Can you point to the circuit diagram you used to build your MPGuino? Did you blow any of the programming fuses?
The Following User Says Thank You to t vago For This Useful Post:
Ettore_M (01-16-2016)
