Originally Posted by t vago
Well, I programmed it into my MPGuino using the latest version of the Arduino IDE, and it works normally. It's actually kind of neat to click on the middle button, and watch brightness actually go down and then cycle back to full bright.
Can you point to the circuit diagram you used to build your MPGuino? Did you blow any of the programming fuses?
That's nice! Thank you very much. You've been really helpful and it's great to know which things works and which don't.
You're right. The fuses. What fuses settings did you use for yours? I should check it now.
Thanks!
Hector
