Old 01-17-2016, 02:04 AM   #4 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by darcane View Post
First, check your oil level...
I've got a bad oil leak right now. If it gets too low, P1259 is the code that comes up, causing it to go in limp mode. It goes away when I fill it back up and clear the codes.
You are seriously damaging your engine. It's because when you go into vtec and it starts pumping oil (and suppose to have more oil pressure) the oil just foams and causes oil pressure to drop, who has triggers the code and disables vtec until the code is cleared. I have seen this code go ignored on a couple insights and it results in dead engines.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Xist (01-17-2016)
