Honda insight parts, Redlands Ca
I have some parts for 2000 to 2006 honda insight for sale.
Engine and manual transmission. About 175k miles on these. Engine ran fine and transmission shifted up and down through all gears fine. I drove this car before everything was pulled out. Complete with sensors, coils, etc. Still together. The clutch was even fine.
Stock exhaust system. The long part with the muffler and resonator. Good condition, no damage
Second cat. This is the one that bolts under the car.
New rear shocks in the box. These are the inexpensive Monroe ones where you have to make the top mount with tubing.
Stock radio. Works fine.
Bad IMA battery. This is still apart. Had either 4 or 6 bad sticks in it, I don't remember. I should have all the parts for this but have not verified.
Both control modules that sit on top of the IMA battery. These worked when removed.
Grid charger. Looks homemade. It worked when removed.
Will figure out prices soon or you can make offers. Selling an insight also, in another ad.
