Belly pan is major benefit and hunting down the lowest viscosity fluids that match the specs you need to meet. NMF I've found is pretty awesome and has saved my ass from overheating on at least 2 occasions and Amsoil heavy duty antifreeze helps too. I also use ws2 in my engine, coolant, and fuel. Upper grille block helps too.
Doesn't have to be anything too expensive. Of course I went further and got flow formed centerlines @ 14 lbs each. Luckily I got them while the CAD dollar was @ $1.10 USD. Not the case now, that's for sure...
