I have read the cause is overheating the lithium ion batteries, which burst open and then start the fire. The overheating may result from overcharging, heavy use, blocked ventilation, bad cells or a combination of these factors.
Even if they would not catch fire I doubt many people on here would be interested. This seems a bit of a kids tool, and most of us are beyond that.
If I had a hoverboard I'd take it apart to use its contents for other projects; to revive a power drill with a dead battery, f.i.. I doubt I would even try it out once.
