CODFISH driving
I did a search on CODFISH and only got the glossry.
1.Do I have to go in neutral before shutting off my engine and coasting?
2.Also sometimes when I am off I'm thinking if my cluster guage is reading speed = 0 mph, then I have to turn the key to accessory so the miles rack up. Otherwise I would not be adding mile to odometer while I'm coasting until engine is turned back on, right?
3.My 2006 Dodge GrandCaravan SXT will not start up from neutral. So It means I have to pull over and stop, put car in Park, then start engine. Does this sound right?
Miles on the Nissan look good from doing this CODFISH technique a little: 320 miles 3/4 of a fuel tank used.
