Originally Posted by Thatdippedstang
As far as Mods, I plan on blocking the grille and installing a kill switch for some good old EOC, as well as forming a partial kammback (I think I spelled that right)
Installing a engine kill switch will
kill your transmission
You can't EOC (engine
off coast) with a automatic transmission. The engine needs to be running in order to supply ATF from the internal pump to all the rotating parts so they don't burn up from lack of lubrication.
Automatic Transmission Pumps: The Heart Of Your Transmission
You can however EOC (engine
on coast) and still get great MPG numbers.
