Old 01-20-2016, 04:50 PM   #3 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
You're rated 12 mpg combined. Jumping that pig up to 20 just isn't happening: I tried with an MT Xterra and only got 2-3 above combined.
A used axle with a better gear ratio can probably pay for itself, and figuring out a way to get that 46RE to lock up will probably be a good move. After that, keep the revs down and DWB, DWB, DWB. The main thing is actually reframing the way you think about it. Instead of seeing it as a low mpg failure compared to your Civic, ask what you're getting for your 12 (14? 15?) mpg. It's probably a lot. Sure, you want to improve mileage, but if you're getting the full utility out of it then it's a win.
PM me the last 8 of your VIN and I'll see what info I can dig up.
Transmission type Efficiency
