Old 01-21-2016, 09:27 PM   #4 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
They sell just the flex piece that you can attach to your existing cat, or you can buy the whole setup with a new cat.
It's Walker 53325 I think for the flex piece and $59 at Rockauto.com Then you can use a universal cat for probably under $100 (I see universal Catco converters on Summit Racing for $70) (or $116 for the Walker Ultra cat at Rockauto)
They whole assembly is about $170 but only the California version shows in stock there (I think it's fine to use a Cal on a federal, just not the other way around if you lived in CA).
If all you need is the flex pipe I would just get it and not replace the converter unless it is actually bad.
