Old 01-22-2016, 08:42 PM   #7 (permalink)
oil pan 4
For engine cranking you only want to run the batteries at about a 5C rate.
Chances are cranking a 4cyl engine with a 10ah battery will likely use between a 10C and 20C discharge rate. 20C is the absolute max on most LiFePO4 batteries.
