Old 01-24-2016, 05:03 PM   #5 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
*If they want meaningful results,then both CFD and wind tunnel testing must be conducted at supercritical Reynolds number.
*Yes,a cooling system would be nice,but I'm not certain that the effect of the VGs would be remarkably impacted by its presence.
*There's scientific evidence which would dispute the need for rotating wheels to obtain meaningful results.
For me,the takeaway from the article is that,the investigators don't understand boundary layer theory,and consequently,their testing methodology and results have zero scientific merit.
Ummm... the fact that the vortex generators show a reduction in drag prove that it was supercritical. Bumps corners and curves tend to create more turbulence than a flat plate. If the flow was entirely sub critical all VGs would add is drag.
Unless they faked data the test shows validity. I think you need some time working with a real CFD package or in a wind tunnel or at least objectivly look at the data befor you make claims it has zero validity.
