Old 01-25-2016, 08:58 AM   #14 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I would design around construction, as the best shell is the one that gets built. I am currently building a shell for my Toyota Tacoma, using XPS foam and will be fiberglassing over it with epoxy. I am about halfway done, and have a thread going on here if you want to see it.
My suggestion is that if the template lands a few inches higher than your tailgate, just build the shell where it is a few inches higher than your tailgate. On my Tacoma, the template landed 5” higher than the tailgate, so I built my shell to match that profile. I chose to extend my shell a few inches back past the tailgate before I terminated it, but I could have ended it right there, and had a vertical drop from the end of the profile. I still might end up cutting that part off before it is all done. Personally I wouldn’t want it to come down to a razor edge right over the tailgate, you need strength right there. With most lightweight construction methods, you need some vertical height there especially if you are incorporating a window. Also I am going to mount my third brake light right there. You don’t want a curve there, you want a nice clean separation where you want the air to let go.
The Following User Says Thank You to aardvarcus For This Useful Post:
Vajra (01-25-2016)
