Old 01-27-2016, 08:49 AM   #112 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I have continued to make progress on the Version 2.0 Aeroshell. The cold has halted my welding or most progress on items that have to be done outside. I moved the shell to my basement to continue progress. I got my front viewing cutout made (no window there) to match the truck rear window. I also cut out for the window on the back of the shell (3’ wide, 4’ long), and I re-cut out the passenger side window to a slightly larger size. I also did some better smoothing of the passenger side. I still need to cut out and shape the driver’s side in the same manner. Then some cutouts and smoothing of the underside, and it will be ready for epoxy fiberglass. Anyway here are some pictures.
ID:	19555   Click image for larger version
ID:	19556   Click image for larger version
The Following 5 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (01-27-2016), BamZipPow (01-28-2016), tacotuesday (02-15-2016), Vajra (01-27-2016), wdb (01-29-2016)
