Originally Posted by Stubby79
Auto axles will mate with the manual trans? Hadn't even thought of that...I'm used to the auto makers having completely different shaft ends for automatics then for manual transmissions!
I might be able to find those around here...
What about the shift linkage? Move the stud over and...? or leave it all alone?
I did move the stud over, but the linkage still runs a little bit diagonally through the tunnel. I also chopped both rods and extended them a little. The shift linkage was pretty trivial, and making the mounts was the bigger part of the challenge. The auto axles fit just fine, but they are a tiny bit shorter. If you add the lengths of both axles together, they auto axles measure out about 1/4" shorter for combined length. I have been running them for years now, and have had no problems with them at all.
