Originally Posted by EVmetro
I did move the stud over, but the linkage still runs a little bit diagonally through the tunnel. I also chopped both rods and extended them a little. The shift linkage was pretty trivial, and making the mounts was the bigger part of the challenge. The auto axles fit just fine, but they are a tiny bit shorter. If you add the lengths of both axles together, they auto axles measure out about 1/4" shorter for combined length. I have been running them for years now, and have had no problems with them at all.
That's good. I just finished mucking around and ordered the axles from rockauto. They were half the price of local parts place, even with a decent discount there!
Yay...more work to look forward to.
But...I
Really want that shaft accessible/useable, and this will do it.
Thanks for the info, EVMetro.
