Old 01-28-2016, 05:56 PM   #47 (permalink)
EVmetro
I am pretty sure that it is 4" on the money, that the transmission moves over to fit between the axles, but you should be able to compare the measurements of the auto axles vs the 5 speed axles to see for sure. I also held the motor and transmission where they go, hanging from a cherry picker, axles in place. This allowed me to move it from side to side enough to feel where the center point was between the axles. Since those auto axles are a tiny bit shorter, it is even more important to center the assembly between the axles.
