Old 01-31-2016, 06:42 PM   #422 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
That's good news, but will have to take into account the various resistance values which each brand uses that in my case are the image below.
All I did was to add a fuel level adjust parameter, much like the existing fuel tank capacity parameter. Upon sensing that the user adjusted the fuel level adjust parameter, MPGuino adjusts the internal fuel used value by the fuel level adjust parameter. It's fairly simple.
Originally Posted by ECONORAM View Post
That LED should work well. I like the fact that both LEDs being on would result in a yellow light output.
