No good. Maybe with 2B5WB...?
Some fun codes:
Build date: 1/29/02
A07 5.9L Engine(EML)/4Sp Auto Trans(DGT)
ADP Heavy Duty Suspension Group
BAZ Alternator - 136 Amp
BGK Brakes - 4-Wheel Anti-Lock
BKJ Brakes - 12x3.5 Rear Drum
DGT Transmission - 4-Spd. Automatic,46RE
DHA Torque Converter - Lock-Up
DJE Front Axle
DMF Axle Ratio - 4.10
DRC Dana M60/248MM Rear Axle
DSA Axle - Anti-Spin Differential
EML Engine - "Magnum" 5.9L SMPI V8
HAA Air Conditioning
HBB Air Conditioning - Rear w/Heater
NAA Emissions - Federal
NBK EVAP Control System
NFT 35 Gallon Fuel Tank
NHB Cooler - Auxiliary Transmission Oil
NHM Speed Control
NMC Engine Cooling - Heavy Duty
SFB Shock Absorbers - Front Heavy Duty
SGB Shock Absorbers - Rear Heavy Duty
SHA Stabilizer Bar - Front
SUA Steering Column - Tilt
TYT LT245/75R16E BSW ALL SEASON TIRES
Z3E GVW Rating - 8700#
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
