Old 02-02-2016, 04:19 PM   #32 (permalink)
aerohead
curving
Originally Posted by Vajra View Post
Yes, I plan on a curvature, haven't decided yet as to how I want to proceed with it. I could do a 1inch in the middle, or a inch at the 1/3 mark. What would you suggest for the curving? The paper (which I found in my tool box at work) shows the line at 8 degrees, with a measure of 7.6875" off the tailgate. - Vajra
For decades I've used a 20' length of 1" schedule-40 PVC pipe as kind of a bendable french curve.
I'll sand-bag in on the roof and pull it down to a few reference points clamped onto the vehicle,letting the pipe establish a continuous contour.
If you take measurements each 12",you can establish your bulkhead stations.
You can do the same with plan-taper by 3M blue-taping the pipe to the vehicle.
Not perfection,but as Steve Howard says,"close enough for jazz."
Vajra (02-03-2016)
