Old 08-03-2008, 09:59 PM   #14 (permalink)
silverfox
silverfox's Avatar
That should work - anything to break the power circuit to the coils (if you power the relay from an ign hot wire and have it latch open with a push button the relay would go back to it's n\c position when you turn the key off) be kind of nice to have a push button that would kill the engine but reset it's self when you turn off the key so all you have to do is start the motor normally
