Originally Posted by redpoint5
Why is reduced efficiency a terrible idea?
An electric AC motor as it stands in the volt is over 91% efficient across its operational range, an automatic transmission is usually somewhere between 75%-90% efficient, I guess I don't see how that can be correct, even if the motor were to become 100% efficient, I still would loose due to the auto behind it.
Unless it is a manumatic?
From what I remember the dual planetary was for "improved" efficiency, but it too has parasitic losses compared to direct drive.
