Old 02-03-2016, 11:42 PM   #42 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Reed View Post
I am a very long time lurker and haven't posted much at all. However, I am also a big fan of full size vans and Dodge vans and vehicles. The four speed Dodge 46RE is a fine four speed automatic transmision that has a lcokup torque converter and overdrive. It is based on the old very reliable and sturdy A904/A727 design so you really don't have too much to worry about in terms of longevity. Making sure the bands are properly adjusted and good fluid is used is about all you need to do. Use the latest Dexron version, VI I think.
Do not use anything but atf+4 fluid in a chrysler transmission. The reason chrysler transmissions have a bad rep is uninformed shops and other people doing maintenance thought, and would preach, that dexron with an additive was the same as atf+4. IT'S NOT!!!!!!!
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
Fat Charlie (02-04-2016), t vago (02-04-2016)
