Old 02-04-2016, 07:16 PM   #139 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by California98Civic View Post
A question... how are you going to wire the engine management stuff and other sensors, which I would think you'd need even for simple things like fuel remaining in the tank? Won't you want some of the other dashboard readouts that the Prius has? Will missing sensors like TPS be a problem? Are you scavenging dashboard elements too, or going without in some cases?
Almost all of the electronic components and wiring harnesses from the Prius V will be reused, with judicious splicing where wires need to be lengthened, or Firebird external light needs to be connected. I plan to adapt the Prius V speedometer into the Firebird dash. I even plan to replace the gas door emblem with the rear side marker from a '69 Firebird to be used as a defacto center brake light. :-)
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
Xist (02-05-2016)
