Old 02-04-2016, 11:04 PM   #71 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Question
Axles showed up...
The outer CV of the long one is really stiff, though.
Finally starting my mounts.
This is to be the front transmission mount. The stock rubber mount will bolt in the flat place beside the tube.
Not sure if the tube is necessary, with the brace below following the same line. Was looking for something I had on hand that would allow me access to the through-bolt in the middle of the rubber mount.
Rear mount will be pretty easy...
Motor end mount, I'm still figuring out. I want clear access to the shaft on that end. Don't want it filling up much space along side the frame rail, either.
Considering location a new mount spot on the frame rail, directly beside the center-line of the motor....but I don't want said mount extending above the motor by much, as I want to utilize the space immediately over the motor.
Kinda like this:
(the mount on the far right)
Experienced thoughts?
