A lot more camber in the roof, and a 'fairly' well faired-in undercarriage. They might get half that.
It's hard to ignore the excentric hub on that second axle.
gumby79 -- I've always thought you could cut a wedge-shaped 3/4 door frame out of a donor at a wrecking yard and have the door close on that. Problem solved.
