Old 02-06-2016, 01:42 PM   #1868 (permalink)
aerohead
eccentric
A lot more camber in the roof, and a 'fairly' well faired-in undercarriage. They might get half that. It's hard to ignore the excentric hub on that second axle.
gumby79 -- I've always thought you could cut a wedge-shaped 3/4 door frame out of a donor at a wrecking yard and have the door close on that. Problem solved.
I think it's a tag axle,for running empty.Notice the daylight under the other side's wheel.
user removed (02-10-2016)
